Idle Air Control Motor Replacement: 01 Sebring
Old 02-24-07, 07:26 AM
I need to replace the Idle Air Control motor in my '01 Sebring. Where can I find a step by step guide on how to do that? And will any special tools be required?
Old 02-24-07, 09:32 AM
Shouldnt require anything special tools. First thing to try is cleaning the throttle body. Remove the air induction hose from the throttle body. Then using a throttle body/air induction cleaner, clean the thottle body. If this shows no improvement, remove the IAC/ABP motor from the throttle body, and clean the pintle on the IAC/ABP motor and the idle air bleed port on the throttle body. If this shows no improvement, replace the IAC/ABP motor.
Old 02-24-07, 09:55 AM
HotxxxxxxxOKC's Avatar
If and when you replace your IACV, you will also have to do a idle air learning calibration. It's may be different for each vehicle, so ask a dealer or consult a Haynes manual for the proper procedure for your car.
Trackbacks are On
Pingbacks are On
Refbacks are On
