95 chevy blazer heater comes on then just shuts off
Old 02-25-07, 05:58 PM
hi, i have a 95 chevy blazer 2 door. sometimes when i start the truck the heater works and sometimes it doenst come on at all. could it be a short in the blower motor some were or the heater switch itself. thanks matt t. when the heater comes on i do get heat i was wundering if the resister could be bad.
Last edited by matmanrocksu; 02-26-07 at 03:49 PM. Reason: i was adding additional info. thank you
Old 02-25-07, 07:33 PM
HotxxxxxxxOKC's Avatar
Does not work at all? Does this mean the fan will not turn on, or there is no hot air coming out?
You might want to see if they have a control panel in the junkyard. That is probably your easiest thing too do right now.
If that has no luck, then I would start looking at the thermistors which are located on the motor housing or somewhere behind the dash.
Trackbacks are On
Pingbacks are On
Refbacks are On
