Where is the clutch-master cylinder on a '94 Accord?
Received 0 Votes
Hello All,
My wife's 94 Accord is leaking clutch fluid very slowly causing her clutch to slowly give out every 2 weeks or so. My problem is that I don't know where it is so I can put more fluid in it. Could somebody help me out here?
Dumb Question: I can use standard DOT3 brake fluid for the clutch fluid, right..?
Thanks in advance for the help!!
Received 0 Votes
check here
Check on the firewall by the brake master cyl. Open hood look on drivers side right under window it should be there. As far as fluid goes not sure on a Honda what type but it should say on the cap.
