Oil pressure gauge is low when I stop
Received 0 Votes
I just bought a 92 Astro van and the oil pressure gauge is usually very high when I drive, but when I come to a stop it goes close to zero. Then once I start to accelerate it goes back up high again and stays fairly high until I come to another stop. Any thoughts?
thanks,
babbabooey
thanks,
babbabooey
That's normal indication on most vehicles. If you don't have a oil pressure light, I would say you are fine. If the light comes on, it is the oil pump in the pan.
Received 0 Votes
thanks,
babbabooey
thanks,
babbabooey
I had the same problem but installed an aftermarket oil gauge instead.
20psi idle 40-60psi freeway and the gauge showed in the read at idle.
