air conditioner problem 2000 silverado
Received 0 Votes
i noticed my air conditioner quit cooling the other day so i raised the the
hood and notced the clutch on the compressor cutting on and off do i
need to replace the compressor or is somthig else that may be wrong
that i need to check.
Received 0 Votes
If it has the compressor sitting on top of the mtr, they have problems with the internal seals and you can see it leaking all over the compressor.
If your compressor is all wet and oily looking that is the prob.
I replaced aprx.25 last year 95-01 1500 chevys, 10 on the 02-04 yukons gmc chevy 1500's.
If you end up replacing the compressor dont go rebuilt, always new. The new ones have been upgraded and you can see the difference otherwise you will be doing this again in 1-2 years. Trust someone elses mistakes!!
Received 0 Votes
I have a similar issue the compressor is going on and off. The smaller line in laymens terms (high pressure I think) is cool but not blowing out. I was going to check the freon level but can't find the low pressure fitting. Any hints? This is a 5.3L 200 Silverado.
