2002 Honda CRV
Received 0 Votes
2002 Honda CRV
I have a 2002 Hinda CRV. Several months ago the check engine light came so I took it to the Honda dealer and they told me to change the front oxygen sensor, so I did. The light went off for about 30 seconds and came back on. I then went to Auto Zone and they put it on their tester and said it was the back oxygen sensor. Same result. The light is as bright as ever and I wasted 150.00 and two hours. Also the SRS light has been on for two years. Any ideas?
Couple of questions, possum.
Did the Honda dealer scan it or did someone there just suggest the O2 sensor?
Any chance you remember what the codes were that AutoZone pulled?
Here's some help on the SRS light:
http://www.geocities.com/myintegra96/srs.html
NOTE THE DISCLAIMER: Disclaimer: SRS is your airbag system (supplemental restraint system) and is sensitive. I do not suggest that you attempt this if you lack basic electronics skills. I assume no responsibility for damage to anyone or anything for following these directions. Use at your own risk.
