1979 Cadi Problem
Received 0 Votes
1979 Cadi Problem
I Have A 1979 Cadi Is There A Way To Byepass The Multi Cylinder Firing System So That It Will Be Like A Regular System, I Already Tryed To Replace The Dist- And Still No Spark, I Have Power To Dist But No Spark I Am Puzzled. Or Is There Something That Im Missing
There is no way to bypass the sysyem if its what I think you are talking about. You are referring to the electronic ignition. It sounds like you either have a bad coil, module, or chankshaft position sensor. Or worse a bad Engine computer. It would be best if you took it to a shop and had them diagnose the electronic ignition system.
Hope this helps,
Billy
Hope this helps,
Billy
