2004 chrysler sebring
I'am having a problem with my vehicle when i turn off my car a sound like a fan kicks on for a couple of minutes then shut's off it's not the cooling fan because the noise is coming from the top of the engine,it seems like only when i have the heater on then buy morning time the car battery is dead,i took it to the dealership and they cant find the problem i took the vehicle several times they cant figure it out. does anybody have a clue
The only other fan that I know of would be the blower for your heater. The next time it does this disconnect the negative battery cable and use a voltmeter to check voltage between the - battery cable and the - post on the battery. Have someone start pulling fuses until the voltage goes away or drops significantly and you've found your problem. Now remember there should be a small amount of voltage present because of things like the memory for your radio. Hope this helps.
I'd pop open the hood and make sure that the cooling fan isn't turning on (if you haven't done this already). The other fan is a possibility but highly unlikely; you would be able to feel the air coming out of the vents in the car if this is happening; do you?
