change timing belt 93 voyager
is there anywhere on the net that i can get step by step instructions to change a timing belt on a 1993 voyager 3.0l v6
any help would be great!
[QUOTE=divot91;1139928]is there anywhere on the net that i can get step by step instructions to change a timing belt on a 1993 voyager 3.0l v6
any help would be great![/QUOTE
Well let me say this. I am a mechanic and have been ofer 30 years.
This is not a job for you.
It must be installed correctly or you bend the valves.
If it is off as little as 2 teeth """CRUNCH"""
Do yourself a faver.
Get it doun
If you do do it yourself, get a manual and follow it step-by-step
Get it doun
not required
I did a google search type in Gates timing belts your model is not on the list. The 3.0 is but for the car not the van. Check it out for yourself to make sure. and be glad you dont have to change it.
