windshield washers
Received 0 Votes
Hello, I have a 1996 camry. One day my washer stopped working, the wipers work fine but no washer spray. I welcome any thoughts, thank you, Al
We own a Camry and our previous was a '95, but I would have to actually go open the hood to be sure. I suspect, as with most cars you'll find it mounted somwhere right on the washer tank, near the bottom. Easiest way to find it is to backtrack the tubing from the nozzles. Have someone push the button while you listen under the hood. If you hear it humming, you may have clogged nozzles; they can sometimes be cleaned with a small needle. Normally they won't all clog at once and/or you'll notice reduced flow or spitting first. If you don't hear the washer pump running either (a) you're not getting power to the pump, or (b) the pump is shot. You'll need a meter to check for voltage.
Be sure to check all your fuses; not sure which fuse washer pump will be on.
Threw the hood up on wife's '01 and the tank is hidden behind the splash guard in the wheel well - can't see the washer pump - and the tubing runs under the fender where it is about 75% inaccessible. Not sure if the older models use a similar mounting arrangement, but if so you may need to remove the front wheel and the splash guard to get at things.
