Large flash and then no power
Received 0 Votes
67' New Yorker - Large flash and then no power
Hi,
I had been charging the battery on my 1967 Chrysler New Yorker when I got in to start it. I turned the key and there was a large flash (I couldn't tell from what direction), a pop in the speakers, and then a complete loss of power. No lights, nothing. The car had started several minutes earlier so I don't think it's the battery. I blew something, I just don't know what.
Thanks
Thanks
Disconnect the battery and look at every fuse! Also inspect your wiring harness, etc. YOu might have blown the main fuse bus and is a major fire hazard.
Received 0 Votes
Charging a battery leads to clouds of hydrogen gas around the bat., which any spark can ignite. Lucky you didn't have your head under the hood!!!!!!!!
Received 0 Votes
Forgive me for being ignorant, but where and what is the main fuse bus. I checked all the fuses and they look good. I briefly looked at the cables running from the battery yesterday, and I didn't see anything that looked unusual, but it's hard to tell because everthing is so filthy and old.
Received 0 Votes
I think Bill's onto it. As a kid me and my mates would get old batterys and put them on charge in a box, we rigged a spark plug up in the box.the result was a loud bright flash that destroys the battery, sometimes not visable as it will warp the plates inside.
P.S Don't try charging the battery in the box trick.
Received 0 Votes
as a,c said you probably shorted out the battery seen this where pos. becomes neg. try another battery disconnect yours if you intend to use jump cables for a test.
Received 0 Votes
also if you dont have another batt. and use jump cable from another car leave that car off to not damage the alt. it also could be a bad ground let us know how u made out. if u use a jump just see if the interior light lights if it does change the batt. use a body ground for neg. cable pos straight to pos. with your batt totaly disconnected.
Previous Thread
Next Thread
