wont idle in cold weather
Received 0 Votes
I have a 92 Chevy S10 (149k miles) that wont idle when it's extreamly cold outside. Once the motor is warmed up, it idles fine. Could someone give me an idea of what could be causing this.
Thanks
Pete
Thanks
Pete
Hello Pete!
What weight oil are you using? You should use a 5W or 10W weight oil when cold out.
If you have that already, I would then look at your temp sensor.
