69 cougar auto tramsmission removal
Received 0 Votes
would someone please be kind enough to explain how to remove a 69 auto transmission, i have jacks, lifts ect. i just need to know the easiest way to do it. I would greatly appreaciate any advice, and thank you ahead of time
thank you b carnell
thank you b carnell
Received 0 Votes
A service manual would be helpful, but probably hard to find. Basically there are usually 3 bolts holding the flexplate(flywheel) to the torque converter, probably 6-8 bolts around the bell house/engine joint, 2 coolant lines, shift linkage and possibly a vacuum line, and the drive shaft.
