2004 Hyundai Elantra Parking Lights
Does anyone know how to change the parking lamps on a 2004 Hyundai Elantra? I took a quick look at it, but couldn't seem to figure out how they came out. Also the bulb that is located behind the heat temperature control dial and the fan speed dial also are out, I suppose that this is a big task to change these bulbs, huh?.
Thanks for your help!!!
I don't know specifically how to take the lamps out for your vehicle, but you may need to remove some screws behind the front bumper or inner wheel well area. Are you just wanting to change a bulb or the whole assembly?
oh, sorry, I just want to change the bulbs. Nowhere I look, has any kind of instructions on how to do this. The best I could do was find out how to change the headlight bulbs. Thats why I didn't even know if it would be hard to change the Fan Speed or Temepature Control Knobs, light bulbs. Thanks Again!
might be best to stop by your friendly local dealers service desk they would probably pull up a schematic for you on their little computer that shows the assembly and where the fasteners are at, most will be glad to print it off for you . Once you figure out about where the fasteners are you would probably have a 50/50 chance of removing it without major damage Good Luck
You mean that there can be damage caused from just trying to replace a bulb. I have had many cars before and the bulbs were able to be changed, without disassembling the whole car. It's just a bulb! Then again, it's probably the dealers plan, so that you have to give up your first born everytime you need a buld changed. I'll just ride without them lit. Thanks for trying to help though!!!!
