Turn signals not working (2001 Jeep Grand Cherokee)
Received 0 Votes
Hi,
I just noticed that the turn signals on my 2001 Jeep Grand Cherokee are not working. So nothing is happening on the inside panel (no light or noise), and they are not working on the outside either (hazards don't work either).
I just had to have my oil gauge fixed a month and a half ago (stayed on 0 even though there was oil).
I checked the fuse information in the manual, and none of the descriptions matched the turn signals. I called Jeep and they said that the radio and inside lights would all be out as well if it were a fuse. And they all work, so it sounds like it's not a fuse.
Thoughts?
Thanks!
Thoughts?
Thanks!
Look in the owner's manual and see if there is a turn signal flasher as well as a separate hazard flasher - if there are two separate flashers I would suspect a fault in the turn signal switch (all the hazard lights go through here as well). If there is only one flasher used in your vehicle, I would suspect the flasher first - inexpensive and an easy fix.
