2003 Pontiac Grand Prix
Old 03-29-07, 04:09 PM
Angry 2003 Pontiac Grand Prix
My digits on my clock and radio went out. It was on , off and now its just off.
How can I replace bulbs in this? Is it pretty hard?
I really miss my clock. everything else works.
Someone mentioned to check my fuses as it may have its own fuse, but I believe if it did the radio would not work either.
Thanks in advance.
B
Old 03-29-07, 06:12 PM
HotxxxxxxxOKC's Avatar
No bulbs. I believe it's just a LCD crystal display. Call dealer for availability and pricing.
Old 03-29-07, 09:25 PM
Do a fuse check. One fuse will be constant power to keep the clock memory and another fuse is switchable through the ignition key. Also check for a loose connection at the radio. If you can't locate a problem source, the radio may have to be pulled and repaired.
