Help!Stuck in parking brake
Old 03-31-07, 12:22 PM
F
My 1997 Ford Escort has been stuck in park for 4 mos. and I don't know what to do. I cannot afford to have someone come over to fix it. The shifter is auto and on the floor.
Old 03-31-07, 02:14 PM
question
Can you shift to netural with engine off?. If so it is the saftey switch. Turn the key to unlock steering and try to shift.
Old 03-31-07, 06:42 PM
G
Received 2 Upvotes on 2 Posts
In the '97 escort automatic there is a little round plastic patch on the shifter console. It's in the upper right hand corner. Pop that off and insert a metal coat hanger straightened out and pretend like you are pushing on a button or trying to touch a lever and you should be able to release the transmission from lock so that you can push the brake and move the gear to neutral.
Old 04-04-07, 05:24 PM
F
stuck in park
I tried both recommendations you've made "Michael Van" & "Goldstar".
I think I will try it with a coat hanger, Goldstar, because I tried to reach that little hole release with a screwdriver and maybe it was too short to do anything.
I'll let you know what happens.
Thank you both for your response.
