98 Chevy 1500
Received 0 Votes
98 Chevy 1500
What will cause the oil pressure to blow the oil ring off the filter on a 5.0? Where could the pressure be building?
Received 0 Votes
Yes there is a pressure relief valve which will be stuck if it is that high.
Question. Do you have engine oil cooler to the coolant radiator?
If so you could use it to possibly free it.
Did this all happen all of a sudden?
Received 0 Votes
You pulled down the mount plate??
The relief valve should be part of the oil pump unit as far as I remember.
If the relief valve is working then the oil pump can pump as much as it can and it will not overpressurize the system because the relief valve regulates it.
Take the pan off and pull the oil pump/relief valve unit off and check it out.
Received 0 Votes
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/08/62/d0/0900823d800862d0.jsp
A site to go to and look at how to pull the relief valve out.
