2001 Nissan pathfinder belts
Received 0 Votes
how do I change the power steering belts and airconditioning belts in my nissan 2001 pathfinder. It is a LE 3.5 litre V6. What tools will I need
A 1/2 breaker bar or equivalent (to put on the belt tensioner).
You should just be able to pull back on this belt tensioner and slip the belts off.
I recommend getting a Haynes or Chiltons manual to help you.
12mm, 14mm wrenches, 12mm, 14mm 3/8 drive shalow sockets, 3/8 drive rachet and atleast 24" of 3/8 extension bar.
A/C belt= loosen the nut on the a/c idle pulley.
P/S belt= loosen the nut on the adjusting bracket from underneath.
The P/S belt adjusting bolt, clockwise= loosing. Counterclockwise=tighting.
Have fun.
