Battery power decreasing, and help identify "buzzing" device
Old 04-03-07, 04:32 PM
L
I have a 1993 Cadillac Sedan Deville and it's only been a month or 2 since I just replaced my car battery.
Last week, I noticed that my car was a little hesitant to crank after I drove somewhere and parked it for a moment. I did an acid test the next day with a glass tube
that has 4 floating balls inside.
On the positive, the cell nearest to the post measured at 75% and the others were somewhere between maybe 80 -100%.
Then on the negative side, the cell nearest to the post measured having 50% activity and the other 2 were at 100%.
I feel like there must be something in the charging system that's pulling down on my battery.
By the way, there's some kind of a device that makes a sort of a buzzing sound when I turn the engine off and it buzzes for a few seconds. It does this periodically.
If anyone can tell me about the situation with the battery losing it's power and the "buzzing" device, please let me know. Thank you.
Old 04-03-07, 06:06 PM
HotxxxxxxxOKC's Avatar
Have you tried to isolate this buzzing noise? Is it coming from the engine side, rear, inside?
Have you had your alternator tested?
Sounds like there may be a faulty ground wire somewhere.
Old 04-04-07, 06:59 PM
L
Reply to HotinOKC
The buzzing noise is coming from somewhere inside the engine
No, I haven't had an alternator test done yet, but I think I will have one done by one of the parts stores here in town.
