Sandrail tranny problem
Old 04-13-07, 11:08 AM
Question Sandrail tranny problem
69 vw motor in the sandrail. she is stuck in third gear. shifter and rod are intact and working. well mostly. if she is pulled out of the third gear range position, she'll roll with only slight drag to the wheels. although not as if the clutch were pressed in. any ideas? engine fixes fine, but this driver knows nothing about transmissions.
Old 04-13-07, 12:57 PM
Question tranny
do you get first gear?
Old 04-14-07, 03:22 PM
get no gear but third. also just found out that when shifter is in 3rd position, vehicle cannot be pushed even with the clutch depressed.
