AC Problem
AC Problem
I have a 1998 Ford Ranger. The A/C is stuck on heat and won't switch to cool. Could this be a bad tstat or switch?
Could be quite a few things. First thing to check - does the compressor engage when you turn the a/c on. If it does not, could be an electrical problem (check fuse for starters) or you could have a low refrigerant charge; some systems will shut off if the refrigerant is low. If the compressor engages when you switch on, check the two lines coming from the compressor; one should be hot and the other cold; if both are luke warm - low refrigerant or possibly compressor bad.
tweeter it sounds like your diverter blend door door driver has failed this was a common problem on some of the Ford explorers. If set up like the Explorer (most likely identical) this link may help I certainly hope this is not against the rules if so saturn apologizes http://www.blenddoorfix.netfirms.com/
Wish I originally had a detailed procedure for my wifes Stratus when her blend door actuator went out.....oh well...
anyways,
he could take a look and see if the door actuator is actually moving when he selected the colder temp. If no movement, then it's the control panel or actuator like Saturn said.
anyways,
