Transmission Shift Light
How do you replace the transmission indicator light on the dash,its on a 1994 Ford Escort
Do you actually need this light? You should not rely on a light bulb to tell you when to shift.
It would require the removal of the entire cluster panel, and then most likely the disaasembly of the cluster it's self to replace bulb.
In my opinion, it's not worth the headache.
