One washer fluid nozzle not working
Received 0 Votes
I searched for washer fluid threads but didn't see a similar situation. My '98 Subaru Impreza's driver-side washer fluid nozzle works fine but the passenger side one does not - nothing comes out at all. Is this most likely a block in the hose or nozzle? If so, how do you unblock these? Thanks in advance!
Steve
Steve
Received 0 Votes
a sewing needle works good too if you need something a little more rigid. I would reccomend taking the rubber hose off the back of the nozzle first so that after you poke whatever is clogging it through it will not come right back and clog it again as soon as you hit the washers a few times. Also, try blowing compressed air through there (ONLY with the rubber hose off or you might blow a hole in it).
Received 0 Votes
Thanks for all the replies, folks! I'm not sure how I ended up fixing it (I just detached the main hose from that nozzle hose and reattached it but it's working fine now). Also, re: the aiming thing, I didn't even know about that so I aimed them properly at the same time. Thanks again!
