Auto Transmission - Toyota Caldina
Hi Guys
I Just joined the family and already need some help. I have a Toyota Caldina 1992 model E-ST195, Engine 3S-FE, Transmission A540H-09B (Full Time 4WD).
When I put the gear on drive the car does not pick up and it moves slowly(I think the vehicle moves on top gear) And the OD light starts flicking. I have tried changing ETC Control and also changed engine controls, checked solinate, but with no help.
Looking forward to your help.
Regards
Regards
Mods: I'm pasting a link to another site that deals with the exact problem this OP is having.
There are some troubleshooting steps in this that you need to do. Take a look.
http://autorepair.about.com/library/faqs/bl153g.htm
Note: This linkis for a 4Runner, but it's the same issue.
anand,
Also, will the car move at all when you put it in gear. You said when you put it into drive it has this problem, does it do better in any of the low gears or reverse? What do you mean "car does not pick up"?
Thanks mate,
The car does well in reverse and low gears. i have checked the trans oil - ok. When on drive. the I guess the car does not chane gears...what may be the problem...
Cheers
Cheers
