Check Engine Light is on!!
We have a 2001 Toyota Seinna mini-van in which the check engine light is on.
I took my handy-dandy scanner and it read the that "bank 1 & 2 lean." What does this generally relate to and how might I correct it??
CD
CD
This is usually a fuel pressure problem or a bad MAF. I would have someone hook a fuel pressure gauge up to your rail and check that. If that is good, I would lean more towards a bad MAF (mass air flow) sensor and then maybe some Air/Fuel sensors.
Bank one AND two lean would indicate to me a rather robust vacuum leak.......I'd be checking all the hoses and connectors I could find.........Fords are NOTORIOUS for PCV connector leaks........maybe Toy has similar issues????
