keyless entry remote!!
Received 0 Votes
I have a 1999 pontiac bonneville and the keyless remote stoped working; I bought a new battery and tried to recincronize it again and it worked a couple of times and then stoped working again. Is there any fuse that I could check or do you think is the remote?, I went to the dealer and they told me that it will cost me $80.00 the remote plus $99 dollars an hour to sincronaze it and I think it's a lot of money. If I have to get a new one What do you think about the ones thast autozone sells?
Thank you for your help
Try this:
1. Insert keys in ignition and leave in the OFF position.
2. Locate the OBDII Port.
3. Make sure there are metal contact pins in terminals 8 and 4. Connect 8 and 4 with a suitable jumper wire (leave the jumper wire connected throughout the programming procedure). Make sure you know which terminals are 8 and 4. The vehicle will respond by locking then unlocking the doors to signify entering of programming mode.
4. Close Doors
5. Turn ignition to the ON position (as far as you can go without cranking the engine).
Doors will lock.
6. Press and hold both the LOCK and UNLOCK buttons together on the first transmitter to be programmed. Up to about 30 seconds, the vehicle will respond by locking then unlocking the doors. Release the buttons on the transmitter.
7. Within one minute, repeat the previous step on the remaining transmitter (if any – including any existing remotes).
8. Remove jumper wire applied to the OBDII Port.
4. Close Doors
Doors will lock.
