Subaru air conditioning not cold.
Old 04-27-07, 12:54 PM
I have a 1992 Subaru Legacy AWD. Engine EJ22. My AC is not cold anymore so I bought a thermometer and pressure check guage. Thermometer does not go below 60 degrees F in my vent and the low side pressure indicates 54, which is way high. What is my problem? Do I have a restriction or is my expansion valve bad or something else?
Thanks,
Neil
Old 04-27-07, 03:57 PM
HotxxxxxxxOKC's Avatar
Is the compressor kicking on?
Old 04-27-07, 05:26 PM
Yes. Compressor is picking up normally. It is getting cold, just not cold enough.
Old 04-27-07, 05:33 PM
High pressure on the low side can damage your system. To get a accurate reading, you need to have the car running with the A/C on high.
If you are still getting high pressure with the A/C running, you need to relieve this pressure by sticking a screw driver end into the low side pressure port.
Does the compressor clutch stay spinning the entire time?
Old 04-27-07, 05:51 PM
If the low side is running high, the high side is probably running high as well..........Are the electric fans operating??????
Old 04-28-07, 09:15 AM
Yes, the compressor stays running for a decent amount of time before dropping out. The fans are operating normally.
