No Cruise Control
Received 0 Votes
No Cruise Control
2000 Plymouth Voyager 2.4 engine>
Cruise Control not working, is there a fuse for this maybe burnt?
Usually this is not a fuse. I'm not sure if there's even a fuse dedicated to cruise control. Most cruise control problems are due to a bad speed sensor, vacuum leak, brake switch, etc.
Check your brakes lights, are they on all the time?
Also, does the cruise light come on at all? If it doesn't, it seems this vehicle has an issue with the clockspring within the steering wheel goes bad and there is a recall for it.
