Anyone an Expert on Tires?
I have a 1994 GEO Metro. The standard tires are P145/80R12. I'm having more and more trouble finding 12" tires. I was told I could use 13". Sears currently has P155/80SR13 tires on sale at a great price. Would those be ok for my car?
Thanks much,
Harold
Thanks much,
Harold
You are going to have to find 4 13" rims. Usually a shop will be able to tell you if they would fit. I imagine clearance is the issue. Before you go out and buy 4 new rims and mount and balance 4 new tires, I would find an old 13 tire and rim in a junk yard and ask the shop to mount it on every 4 positions and check the clearance. It shouldn't throw off your alignment since they will all be the same size. It might throw off the speedometer a little but I am unsure of that.
Can also find them on line and have them mounted locally. How much hassle do you really want to put in on a 13 year old Metro. I'm guessing it'll have about enough life left in it for one more set of tires. Here's one on-line supplier, although it appears to be a snow/ice design:
http://www.1010tires.com/tire.asp?tirebrand=Kumho&tiremodel=KW11
