1992 Cadi Sev A/C Problem
Old 05-08-07, 12:08 PM
K
Drivers diplay: A/C low in refrigerate A/C compressor off
gased up now w/refrigerate but it still says A/C compressor off
can you help me solve the probelm
Old 05-08-07, 01:39 PM
HotxxxxxxxOKC's Avatar
It could be a few things but it sounds like a failed a/c compressor.
The seals on the compressor might be faulty causing the refrigerant to leak out causing your warning indicator.
The problems can be difficult to troubleshoot and sometimes costly because it may involve shotgunning parts.
You can test and see if it's a compressor problem by jumpering the relay. You will have to have a relay diagram of what spots to jump.
If you can get the compressor to kick on by jumpering it, you may have a high/low pressure switch bad.
Those are usually the main things.
There are other possible problems as well, like the condenser, etc.
Old 05-08-07, 06:13 PM
W
I assume (dangerous word) that you have gauges on the unit and you're not leaking out as fast as it's going in????.#1............disconnect the neg terminal from the battery and clear the codes...........See if they reoccur..........There's a BULLETIN (I know Mark HATES those).........on the PROM for the ECU that helps
Old 05-08-07, 07:13 PM
Wrench...
I just don't like how the TSB's are so vague. Some of them may offer some good help.
