screaching
screaching
i just put in a new tps gasket and new plug wires hooked everything up and now when i let off the gas pedal a screahing noise is made and i have no idea what it is
You did put this TPS on correctly afterwards? If this sensor is caulked at all, it will create this sound. A TPS is a type of potentiometer so if it's not lined up right, the TPS, and throttle body will be off.
I recommend taking this back apart and making sure it's installed correctly.
