93 plymouth voyager ac/heater controls
I noticed on saturday when I had my a/c on that my controls don't work on low or medium they do work on med.high and high this is both with the a/c and the heat is there A wire that could be disconnected for the low and medium or what could this be thanks for any help.
Most likely there are some bad resistors that are not allowing the other speeds to work. The resistor block is usually mounted near the air box under then dash. If it's not that, it's the controls.
