engine running fast
Old 05-14-07, 03:40 PM
Smile engine running fast
I have an 84 Cutlass, that I've been restoring. It's been running fine, but now at idle it revs up and I can't get it to idle down. It's even tough to hold it back with the brake. any ideas on how to correct the idle
Old 05-17-07, 06:10 AM
carguyinva's Avatar
fast idle with carb
vacuum leaks, choke not heating up and coming off of fast idle cam or cam stuck, faulty idle speed control if it's a 3.8 v-6 OR faulty idle load control if it's a 307 v-8. if it's a 305, it uses neither. also base idle adjustment can be way off. jeez...been a long time since i thought about carbs!
