1992 toyota corolla
Received 0 Votes
1992 toyota corolla
i have a 92 corolla that the ac wont kick on but the switch works and the pump belt turns also i was told to check the ac relay fuse but i cant tell which one it is i have a relay box that has 4 different fuses in it that is all for the ac
If I understand your description the clutch is not engaging? Possibly the refrigerant is low and the pressure switch is preventing it turning on. You can force the clutch by disconnecting the plug on the compressor and applying 12 volts. This is a quick check only; you will still need to ensure the system is properly serviced to prevent any chance of damage.
