Chevy S10 Intake Mano Coolant Leak
After searching I found a coolant leak where the mano bolts onto the
head(s). How many bolts hold on the intake mano? How do I get the pulley off the steering pump to remove the bracket holding the pump so I can get to the mano bolts? Any other suggestions?
Thanks, JimK
Thanks, JimK
Two ways. 1. Leave the p/s pump bolted to the bracket and unbolt the bracket, pump and all. 2. If that won't work the pulley comes off with a special tool; may be able to rent/borrow one from a parts place like Auto Zone. Here's what they look like generally:
http://www.jcwhitney.com/webapp/wcs/stores/servlet/Product?storeId=10101&Pr=p_Product.CATENTRY_ID%3A2010654&TID=231000000&TID=231000000&productId=2010654&catalogId=10101
