Broken Key
Old 05-25-07, 07:11 AM
Broken Key
My key broke off in half inside of my driver side door yesterday. Now I must get in through the passenger side. Is there a way to remove that with a special tool or getting a locksmith or chalking it up to damage control. It is a 91 so I do not have auto locks or keyless entry. Please help?
Old 05-25-07, 07:19 AM
HotxxxxxxxOKC's Avatar
If you can get a strong enough magnet, that may work to get it it.
If that does not work, you will probably have to replace that lock.
Old 05-25-07, 11:28 AM
thiggy's Avatar
I think it is unlikely that any auto key would be magnetic.
Old 05-25-07, 12:24 PM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Some help:
http://www.sqlhelper.net/html/Home_Improvement/03/Broken_Key_Removal__Pin_Tumbler_Locks__7719.html
http://www.goldkeyselect.com/brokenkey.php
Old 05-25-07, 12:43 PM
Thank you everyone, I have some sense of direction now and will work on this wknd! Cheers!
Old 05-25-07, 03:50 PM
Received 30 Upvotes on 29 Posts
Well.. If you can see the broken end of the key in there you might try a hair pin with a touch of quick set JB Weld on it. Prop the little gate open with a toothpick, hold the pin on it long enough to stick tight and it may get it out for you.
I've never done this, but I would really like to see someone try it.
Hope this helps,
Bob
Old 05-25-07, 03:52 PM
Of course, you didn't specific a 1991 *what*.
On many cars (like my T-Bird), the lock is held in place by a spring clip that slides through a slot in the door jamb. Open the door, pry the clip out, and the whole lock falls into my hand. 2-minute job. Yours may be different.
Old 05-25-07, 07:21 PM
G
Received 24 Upvotes on 23 Posts
put a little super glue on the other part of the key, insert the key, wait a few, remove old key. Have a good one. Geo
Old 05-26-07, 06:28 AM
I would try that as a last resort in case you err with the glue and end up with it permanently glued into the keyslot.
Old 05-26-07, 06:58 AM
Received 1,197 Upvotes on 1,152 Posts
I would suggest paying a locksmith to remove the key before using super glue.
