1993 Cad DeVille
Received 0 Votes
1993 Cad DeVille
Help!!!! Will not start. No spark. Changed coil, new battery. Looking for wiring diagram or other sources of info. Do not have owners manual. Any suggestions would be appreciated.
Received 0 Votes
i had this problem in my 91
you need to replace the ignotion module it is located in the distributor underneath the rotor there will be a rectangular flax black box with 2 screws thats what u need to change
The module isn't a 100% chance of fix, but it would certainly be high on the list.
Also wouldn't hurt to pull codes just in case. It's DIY on you old Caddy:
http://www.troublecodes.net/GM/
Received 0 Votes
1993 cad deville
Tanks for the info.We are going to get another modual.We are doing this without a manual .I guess were trying to beat the manufactures and do the basics .This is my first on this site that i found by accident.Its great info.
Its my fathers cady and Im trying to help him.Thanks again for the tip on the modual.
Don't forget to pull the codes. I had a no-start on my wrecker last year that drove us crazy until we discovered it was a bad temp sender (for the computer); there was a code stored, but we were convinced it was a coil/module/etc.
Received 0 Votes
93 cad deville no start
We did replace modual in dist. and rotor with no luck.We will do cap next.A mechanic told us there is a sensor on the passenger side under wheel that I have never heard of ,except for a speed sensor for ABS which are on all 4 wheels.He said you have to take wheel off to get at it.We havent found a manual yet.I guess we will have to go to alldata.com or go to library.
Cant pull the codes on this car unless you have scanner.This car does not have have Aand B terminals needed to get code counts with out scanner.
Received 0 Votes
Test light the ign coil...........First for power TO the coil..........Then for pulse as the engine cranks (By placing the test light on the NEG side of the cooil when cranking, light should flash)..................This sounds more of a ccc kinda set up where the car STARTS on the pick-up in the dist, then switches to computer control after @400RPM...........I'd check the ign coil as I staed firsr before replacing any more parts.......At least THEN you'll know whether the problem is Primary or Secondary
Received 0 Votes
first check power to the distributer at pos side of coil then would probably suspect pickup assembly in the distributer if you have no spark, sounds like you have replaced most of the ignition system, coil, rotor,module, you have to remove the distributer to replace the pickup.
