99' Malibu Code P0302 Misfire #2 Help?
The car runs terrible at times and loses power. I get an on and off code of P0302. In addition, it seems my antifreeze gets low and the car will over heat. I am not sure if they are both related. I changed the plugs, wires and switched the coil pack to see if i could move the problem. I am thinking maybe it is the fuel injector being clogged but wanted more opinions. Please help?
You most likely have a blown head gasket. Bring this to Chevy and they should replace it sucking up all the costs. There was a recall on this but not sure if your car was effected. Either way, blown headgasket.
