1997 murcury grand marque fuel pump
Old 05-30-07, 08:09 AM
P
What is the easiest way to change out the fuel pump? I was told that I could cut a hole in the trunk to get to it. If I could where would I cut the hole and how big should it be?
Old 05-30-07, 08:36 AM
HotxxxxxxxOKC's Avatar
Cut a hole in your trunk? YIKES!
Dropping a fuel tank is not that hard. It's held on by just 2-3 straps.
Get a syphining hose at a auto store, drain the tank (if you want)
Place floor jack with a small block of wood on it, and place it under tank.
With straps removed, carefully, and slowly lower tank enough to make sure the fuel lines will not get damaged.
I would not however, cut a hole in your trunk. Some vehicle, like mine, require you to just pull out the back seat and remove a small access door to gain space to the fuel pump. Check your trunk or a similiar door.
Here's the actual how-to procedure:
Fuel tank lowering:
http://www.autozone.com/az/cds/en_us/0900823d/80/17/37/9b/0900823d8017379b/repairInfoPages.htm
Fuel pump removal:
http://www.autozone.com/az/cds/en_us/0900823d/80/17/37/a6/0900823d801737a6/repairInfoPages.htm
Old 05-30-07, 09:18 AM
Received 2 Upvotes on 2 Posts
It's not easier to cut a hole in the trunk by any means
Like Hot mentions, you may have an access hole you can look for
-which I would look for first, but-
I believe you have to drop the tank on the Marquis
I haven't looked at the AZ instructions, but usually the A/Z ones are as good as any aftermarket manual
I would drain as much fuel as possible out
Use the jack/woodblock to support it (as all the fuel won't come out, it could be heavy) during removal
And def. remove it all the way after "dropping" it
Don't try and 1/2 drop it to save effort
It just adds effort to try and work under there with it 1/2 hanging off
Old 05-30-07, 11:12 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
And just a wild idea here, but if you are changing it because the pump isn't running, have you checked the inertia switch to make sure it isn't tripped?
Old 05-30-07, 01:14 PM
The Ford/Merc Inertia Switch
If it's tripped by an accident (or speed bump or spirited trunk loading), the pump is disabled until the switch is reset
The cover in the trunk plastic "lining" will be marked and can be removed to access the switch
It usually is a button that must be reset by pressing down
