AC oil
Old 05-31-07, 10:22 AM
E
Question AC oil
I have a '97 dodge stratus that i just replaced the AC compressor in but I'm not to sure how much oil needs to be put in to the system.
Old 05-31-07, 01:06 PM
HotxxxxxxxOKC's Avatar
The cans of 134A have this oil in it already.
If you disconnected the A/C lines in the process of replacing compressor, a complete vacuum and recharge is in order. Having lines disconnected introduces moisture in the system and cause damage.
Old 05-31-07, 01:35 PM
E
I know some brands of 134a producers do put oil in with there refridgerant but if it enough to service a new compressor? I've found that most cans of refridgerant contains about 2oz of oil.
Old 05-31-07, 04:32 PM
The following is from my AllData I have for my '01 Stratus. It's probably the same.
Refrigerant Oil
Total System 150 ml (5 oz.)
Condenser 30 ml (1 oz.)
Evaporator 59 ml (2 oz.)
Receiver-Drier 30 ml (1 oz.)
Refrigerant Lines 44 ml (1.5 oz.)
Compressor See Note
Note:
When replacing the A/C compressor, drain and measure the amount of oil from the old compressor. Add the equivalent amount of fresh oil to the new compressor.
Copyright © 2007 ALLDATA LLC
Old 05-31-07, 06:35 PM
W
You replaced the compressor because??????????.............If the old one came apart internally did you flush the condensor?????............Older car??? Did you replace the receiver drier and the expansion valve??????...........
Old 05-31-07, 09:15 PM
E
i replaced the compressor becuse the clutch on it went out, the compressor itself worked fine before the clutch gave way. No, i didnt replace anything but the compressor.
thanks for the oil quanity info.
Old 05-31-07, 09:30 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Have to ask why not just a new clutch ?????????
Old 05-31-07, 10:40 PM
E
i tried, couldnt find a clutch assy, the best i figure it all comes together. if not i still couldnt find one. sometimes you just draw the short stick, right.
Old 06-01-07, 07:55 AM
B
would add atleast 2 ounces to the compressor you can buy freon with oil in it already but the oil should really be added directly to the compressor and turned over several times by hand before even installing.
what exactly was wrong with the clutch was it making noise and slipping and discolored from being hot if so you will likely be doing the job again in the near future might want to flush and change out the drier the second time around.
Old 06-01-07, 08:03 AM
E
it was more likr the clutch bearings gave out. the clutch froze up but the pump was still turning.
