AC Clutch Adjustment
Old 05-31-07, 03:46 PM
Question AC Clutch Adjustment
I just had a new AC compressor installed in my 96 Chevy Blazer. The compressor clutch only kicks in when I tap it or hit a bump on the road. Is there a way to adjust the clutch so that it comes on automaticly when I turn the AC on? I've checked the pressure,the freon and jumped the switches and they're good. Do I need another new compressor???
Old 05-31-07, 04:34 PM
HotxxxxxxxOKC's Avatar
Sounds like whoever put the clutch in, didn't put the required shims in place preventing contact.
You will need a repair manual, and a thinkness gauge to shim it correctly.
Old 05-31-07, 06:15 PM
What is the air gap on this compressor????.............ALSO check for system voltage at the compressor plug and a good ground............Any resistance will have a negative effect on the electro magnet that hauls in the clutch face
Old 06-01-07, 09:23 AM
Take it back and have them adjust it, if too much air gap.I believe the gap is .020, about a business card thickness.
Trackbacks are On
Pingbacks are On
Refbacks are On
