hat70087 (1996 Hyundai)
Received 0 Votes
have a 1996 hyundia, when i try to start it i get nothing, it dosn't even click, battery fine, all wires connected, just don't know what to check to fix. can anyone help?
++Mods Note: For future posts, please provide the issue you are having in the Subject line, i.e. Hyundia not able to start, etc. This will allow future searching abilities for the archives.++
It is probably your starter or possibly a alarm issue.
Do you have a factory or aftermarket alarm installed?
You should check to see if you have voltage down to the starter when turning on car.
Received 0 Votes
If you're ok removing it on your own if you bring a starter into autozone they will test it for you.
But before you go racing out to get it tested make sure the starter itself is grounded well and check the ground lead off the battery that it's still attached to the frame good. I doubt it's either one of those but it's possible and they're easy things to check before you start digging in too deep.
Received 0 Votes
Before you get to rippin parts out..........Test light the small trigger wire that sets the starter off...............You can also try a jumper from the main lead to the trigger............If the starter spins it be OK.............
