Quest rear a/c
Old 06-02-07, 11:07 AM
H
Quest rear a/c
Does the rear ac require charging seperate from the primary system?
Old 06-02-07, 12:05 PM
HotxxxxxxxOKC's Avatar
No, it should not. There should be only one system.
If you are not feeling cool air out the rear vents, it might be a bad mode/blend door.
Is this what is happening with you?
Old 06-02-07, 02:17 PM
H
Yes willl check right away. will let you know.
thanks
Old 06-02-07, 02:44 PM
Also, what year Nissan is this?
AFter reviewing some info, it looks like there are TWO evaporators, one for front, one for rear, but just one compressor.
Old 06-03-07, 10:05 AM
H
Therer is two but the problem was a pinhole in the feeder to the rear unit. Thanks all, will replace the line.
