air conditioner
i'm trying to gas up my ac in my 1989 ford escort but can not get compresser to com on and can not find a fuse for it can some one let me know were to look tank you
Could be multiple problems.
First thing I would do is check for power at the A/C compressor relay in the engine bay. If you have power there, then you can try and jumper those two relay terminals with a small piece of wire. If the compressor kicks on, the compressor is good, and now you either have a bad pressure switch, or a control panel problem.
You may need a Haynes manual or similiar to now what terminal in the realy box too jumper.
