1997 tOYOTA aVALON xls
I Changed Rear Struts On My 97 Avalon Had To Take Hydraulic Brake Line Loose Cause I Put Strut On Wrong Side. I Have Bled The Brakes 3 Times But The Abs Light Stays On. Also The Traction Off Light Blinks All The Time.what Did I Do Wrong & Can Anyone Help Me Thanks Gevinsky
You most likely damaged a ABS sensor while changing the struts. Go to autozone and get your computer read. There should be a code for the ABS malfunction.
If it's not the sensor, then you might want to look at your wheel bearings.
Inside of the master cylinder, there is a multipurpose device called an equalizer, or metering valve, or proportioning valve. When you bled the brakes, it shifted off its normal position, and the car thinks that the brakes are bad. That throws on the warnings that you see.
