92 Toyota Camry-Sensor Problem
I am having problems with my 92 Toy Camry. Came home and parked it and it would not start again. It turns over and cranks but will not start. I replaced the fuel pump and that was not it. The problem seems to be in the fuel system. I have tried to locate the camshaft sensor but can not find it. My manual shows it only for a V6, but my car is a V4. Can anyone tell me where the sensor is located? Thanks.
On most vehicles, the CPS is located near or under the intake manifold on the engine.
There are some people on this forum that have had Camry's, so hopefully they will chime in to give you more detail.
I think its your distributor.If u can check the voltage and make sure there up to specs.another way is to make sure its getting good spark.You said u already replaced the fuel pump.I just got done doing the same thing last week.She came home and parked it and then all of a sudden it wouldn't run.Just make sure you verifyif it is getting spark or not.
