ford f-150 1993 headlight assembly replacement
hello all....trying to install new replacement headlight lenses on my 1993 ford f-150 pickup---how do i reach those retaining bolts on either side of the anber parking lamps below the headlight itself ??-this will allow the parking / signal lamp assembly to come off exposing the entire headlamp--i know i will have to remove the battery on the pass. side and the coolant resorvoir on the drivers side ..but it still looks quite impossible..also ..light beam height adjustment after the fact--any rule of thumb to go by??
These things can be a pain in the rear sometimes.
Try this link and see if any of the info helps.
http://www.autozone.com/az/cds/en_us/0900823d/80/0a/39/3f/0900823d800a393f/repairInfoPages.htm
