1995 Toyota Camry Front Motor Mount
Old 06-14-07, 04:38 PM
C
Question 1995 Toyota Camry Front Motor Mount
How much will it cost to have the front motor mount replaced on my 95 Camry? I know the part is about $127.00. Thanks.
Old 06-15-07, 10:17 PM
G
Talking
a 127 bucks for a motor mount? that aint right. what is it like gold plated or something?
Old 06-16-07, 09:28 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Not exactly, but it isn't just a couple of steel plates and a big rubber bushing either. I'm assuming your talking about the big one in front.
Pretty fast job; less than an hour by the book would be my guess, so it depends on the labor rate in your area. Tip: have it done at a good independent shop vice a dealership; that should save you some. Also might want to check for other sources if the $127 is a dealer's parts department price. You can even get an entire set on ebay for under $110 (this is for a 4-cyl; you didn't mention your engine):
http://cgi.ebay.com/ebaymotors/92-93-94-95-96-TOYOTA-CAMRY-MOTOR-MOUNTS-ENGINE-SET_W0QQitemZ8045200175QQcmdZViewItem
