2006 Toyota Corolla keyless remote programing?
Old 06-15-07, 10:44 AM
P
I got a keyless entry remote for my Corolla, from another Toyota car. Is there a way to program it to be used on my car without taking it to the dealer?
Old 06-15-07, 12:33 PM
HotxxxxxxxOKC's Avatar
Try these:
Start with the key out of the ignition. Open the driver door (all other doors are closed). Driver door is unlocked (other doors don’t matter).
Perform these steps within 5 seconds
Insert the key into the ignition (don’t turn it) Pull key out
Perform these steps within 40 seconds
Close, then open the drivers door.
Insert the key into the ignition (don’t turn it) and pull it out.
Insert the key into the ignition and leave in the ignition.
Close the drivers door
Turn the ignition to ON (as far as you can go without cranking the engine), then back to off .
Remove the key from the ignition.
Within 3 seconds, the power door locks should lock then unlock automatically indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point.
Press the lock and unlock buttons on the transmitter simultaneously for 1.5 seconds
Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should lock then unlock once indicating successful programming. If the door locks cycle twice, repeat steps 6a and 6b as the remote was not accepted.
Open drivers door
done.
courtesy of: programyourremote.com
